I've got it! bolt goes thru the tour pak then the washer then the nut,tighten, place tour pak on top of rack(rest of extended bolt) thru holes on two up rack place washers then nut on bolt,tighten & your done. I've got it. and thank you! Why they don't have some kind of gasket between them is beyond me.
Yes. If you are getting a 14 up style TP the bolt is part of the metal plate in the bottom of the TP...it's pressed in. If you got the older style TP there is an actual bolt that goes through holes in the metal plate.
Good to know,I thought I was gonna have to cut a pc.of plate and drill holes to go thru it.
Thanks to all who attempted to help!
