rear light for M8 Road King
I'm looking to replace the rear lights on my 2018 Road King. I would still like a red lens with LEDs and maybe low profile. Also would like to eliminate the stock rear blinkers so maybe integrated turn signals as well. If you have a personal experience, positive or negative. I'd like to hear it. Also, how easy is it to remove the turn signal arm and does it leave any holes exposed? And while on the topic how about the lights that go between the saddlebags and fenders? Running only or turn or brake? Thanks.
We have a couple of products that will allow you to do this easily. Removing the rear turn signal bar is not too difficult; you just need to unbolt it from the fender and unplug the turn signals from the circuit board behind the taillight.
Once that is done, you can install our Turn Signal Eliminator Kit, which will cover the mounting holes in the fender, and will replace the tag bracket that's on the turn signal bar.
https://www.customdynamics.com/turn-...r-touring?cat=
After that, I'd recommend installing our ProBEAM Fillerz into the saddlebag support rails. They are plug and play, and will operate as running lights and turn signals on your Road King. In the photo of the Electra Glide that I've posted below, you can see them in between the fender and the saddlebags.
https://www.customdynamics.com/probeam-fillerz?cat=795
__________________
Custom Dynamics® - EVERYTHING To Light Up Your Ride!®
15 Cypress Drive
Youngsville, NC 27596
sales@customdynamics.com
http://blog.customdynamics.com
Review Custom Dynamics
Phone: 800-382-1388
15 Cypress Drive
Phone: 800-382-1388
You're welcome! We don't have any options for covering the mounting holes without also including a tag mount, but perhaps another forum user knows of something.
