Is A/C upgrade and tune worth it?
Not planning to do anything that will void my warranty on my new '19 Street Glide Special so not considering any thing aftermarket for now.
I have already replaced the stock slip ons with Magnaflows. From what I understand these will not have any effect on my warranty.
I'm contemplating installing the Sreamin' Eagle High-flow Air Cleaner Kit - Wedge (p/n 29400246A) and tuning with the Screamin' Eagle Pro-Street Tuner (p/n 41000008C). For these two items, from Surdyke it will run me about $425 (since I have the tuner cable already).
The 114 runs great and more powerful then I really need but would like some opinions please. Is this, sort of a part ial Stage I upgrade, worth it and will I see any noticable performance benefits.
I did the same thing on my '18 Heritage M8-107 and it did make a difference, but I do not know enough about the touring model M8-114.
Thanks
Thanks
Thanks
Thanks
From the owner's manual:
Damage caused by installation or use of non-Harley-Davidson components, even those installed by an authorized Harley-Davidson dealership, that cause a Harley-Davidson part to fail. Examples include, but are not limited to performance-enhancing powertrain components or software, exhaust systems, non-approved tires, lowering kits, handlebars, add-ons connected to the factory electrical system, and so on.
Having the tuner set up for stage one I see no real need to slap it on the dyno. There are a few in the M8 section that have done it and gotten positive results the gains are not what they were with the Twin Cam's. I am running V&H Eliminators and a K&N. The bike runs fine with the download. The SE tuner will Auto-Tune to a degree if you are inclined to mess with it.
FrankEV (03-31-2019)
I'm just repeating what I heard/read but I believe the new intakes on the M8's can already flow more volume of air then the engines requires. Unless you are changing it for looks, I'd just put the stock replacement K&N air filter in it for a little less restriction and then look at mods when the warranty runs out. The street tuner is still going to keep you in EPA guidelines so the improvement will be minimal.
