Seat Bolt
Old Apr 10, 2019 | 09:13 PM
steelerdude1's Avatar
steelerdude1
Revolver Cylender, with empty 22LR cartridges I Shot. Comes with empty’s to glue in, but decided to use some I shot. Easy on and off, and fairly cheap.
Old Apr 11, 2019 | 03:10 AM
Drac 1's Avatar
Drac 1
Thanks for all the suggestions.
Old Apr 11, 2019 | 05:34 PM
Drac 1's Avatar
Drac 1
Originally Posted by Red
Do you open your tour box lid to make it a straight shot?
Yup.Always.
Old Apr 11, 2019 | 06:09 PM
Zerk's Avatar
Zerk
Originally Posted by Fireball Jack
I have one of these. 5 bucks and done.
https://www.ebay.com/itm/One-Black-A...MAAOSw44BYGpRw
I like that. Nicer looking that piano key. But with my tourpak you can't see it anyways.
Originally Posted by AFSOC_Commando
I have this one and it is a wonderful seat bolt! You can use your fingers or hex wrench.
The only thing you need to watch is the washer can come off, I ended up ordering spares in case since it provides tension on the bolt.
Do you really need the washer? With the piano key, I am not using one. I got bin full of washers. But they are not black.
Old Apr 12, 2019 | 07:55 AM
Brewmany's Avatar
Brewmany
I also find it helpful to pull the "Skirt" material from the passenger backrest up- makes it a bit easier to see anyway.
That factory screw head is too big to work with my retention screw driver, so when I install the screw, I use masking tape to attach the screw to the screwdriver- it holds the screw in place and once it's tight, just pull the screwdriver away and the masking tape tears away.
Maybe I'll check into one of those custom bolts, but that one is $20- lot of money for a small bolt.
Old Apr 12, 2019 | 09:56 AM
tpcowfish's Avatar
tpcowfish
wrap duct tape to end of screw driver, ,push on tape to screw when seated
Old Apr 12, 2019 | 01:03 PM
AFSOC_Commando's Avatar
AFSOC_Commando
It is a Neobond or Neoprene EPDM Bonded Sealing Washer ( same thing ), It provides tension. My seat moved around slightly when a shop that worked on my bike lost the washer. I ordered more and I think it makes more difference when you only hand tighten. It comes with the washer and if you are careful it is fine. I think the thread length has something to do with it as well.
Old Apr 12, 2019 | 01:43 PM
Ron750's Avatar
Ron750
You can use a screw, or an Allen head screw. I like to use a bolt. Get a 1/4" x 20 x 1/2".
I first used a 3/4" but switched to the shorter. Less chance of hitting tire..
Old Apr 12, 2019 | 05:22 PM
Spartanden's Avatar
Spartanden
I went to McMaster-Carr and bought some knurled **** screws. I use stainless with stainless washers. I understand about the tour pack being in the way, I do not have one. But I do remove the racks and back rests when I need to. McMaster-Carr is a good source for lots of miscellaneous parts/fasteners, etc....
Port City Hog
Nov 27, 2010 09:03 AM
Our07Ultra
Jan 5, 2010 01:00 PM
ziggiegreen
Aug 22, 2008 10:00 PM
Jor3lBR
Jun 30, 2008 06:39 AM
bobby5
Apr 22, 2008 06:41 PM
