Harley Lithium Battery?
I bought a regular battery about a month ago if I had a do-over I would buy the lithium I did more research on it after I bought a AGM battery.
Keep in mind if you use a battery tender you will need a proper tender for the lithium. I found that they have tenders that will charge both types of batteries.
Part of the appeal to said battery is that it doesn't need to be on a tender - not for 12 months... no need for daily, weekly, or winter charging
It's also 3.34 lbs vs 21 lbs, 480 CCAs vs 405, and double the life.
$246.84 on Surdyke. Pretty sure I'll be picking on up once my AGM goes...which it is.
They are lithium iron, not ion, it's more stable than the older chemistries. Their is a risk as with anything, regular lead acid batteries can and do explode too.
JayStronghawk (04-11-2019)
Will it actually do that? Not sure, but it would be amazing.
