Has anyone had an issue with the 'run brake module'
The only problem I ever had was that the difference between run and brake was not enough. If the person behind you isn't paying attention, its hard to tell the difference after you hit the brake. I switched it for the Tailstopper. One running light, three brake lights. Very attention grabbing when you hit the brake.
http://www.biketronics.com/bt400-tailstopper/
Slowpoke62 (04-17-2019)
If you are using original incandescent lamps, they will get hot and may melt the plastic lens if they are too close
I am running CD LEDs all around with their module and there is a significant difference with intensity between run and brake and turn signals and no heat issues.
I had an issue with my lenses melting, but found that my brake light switch got stuck, and was lighting them up like the brakes were applied all the time.
I had a red dot light come on my speedo that brought it to my attention. Not sure if that’s a 14+ thing, or if that warning light has always been there.
Switch to LED bulbs (Amazon) no heat no problem ---except you will also need a voltage modifier ( Also Amazon --https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1 ) Then really no problem.
