fixed calipers and floating rotors
I suspect you'll find the lack of clearance is the same on both sides, indicating the wheel is sitting offset. Not sure if the spacers are the same size on this year bike, but they weren't the same on previous years. The difference was small, but the clearance was small too.
The spacers do ride against the bearings. So if the bearings are not properly pressed in, this could also offset the wheel.
I'm glad I'm not the only one who has never heard of a floating caliper. Like I said I don't want to disassemble anything just so that I can State my case that nothing has been done and the issue is on the parts or the install that they did. They really have nothing to argue about except for the front rim being from another bike other than that all they did was install tires. I just went out there again as I have several times, because every time I go out there I either see something else that can help my case or I think of a different way to word it to the shop to show that the air is on them. With the way it's rubbing on the caliper itself I don't see how in the hell they installed it easily. It would seem like it would be I talked to cram everything together if something was out of alignment
Just for ***** and giggles couldn't they take the bearings out of my stock rim and put them on to this rim?
I was wrong in my earlier post about where it is rubbing. After a little further inspection it is rubbing on the outside of the brake side rotor and inside of the clutch side.
proof that everything is a shifted over
Did the guy perhaps press the bearings in wrong? Primary side bearing in first, all the way against the rim. Opposite side in to just touching the spacer. Valve stem is on the 'opposite' side.
He can say whatever he wants, but I installed a 18" airstrike wheel on my last 08 bike with no hassle.
The following 2 users liked this post by caulk04:
08xl1200r (04-16-2021),
Campy Roadie (04-29-2019)
Then the tech came in and said I habe the bastered year 08.
Thanks to all of you for confirming what I thought. I didn't have a lot of time to talk with him yesterday because I had to get home to get my daughter off the bus. It's probably a good thing because I go straight from being rational do are rational really quick and I don't want to be a dick and then him not try to remedy the situation. Today I plan on printing out a part numbers for 07, 08, and 11 just for further proof as well as a picture of the old style caliper versus a Brembo. I should have a chance to go up there today and chat with him for about half an hour I will get back to this after that conversation and let you all know what was decided
