fixed calipers and floating rotors
04-17-2019, 08:35 AM
Lemme know what you find. That spacer moves the primary side bearing out to the left just a tad which in turn will move the wheel to the right. This only applies to those Bastard 08's. Been there before.
04-17-2019, 08:36 AM
opps nvm bates. its shifted over to the brake side. so if a spacer were to be installed on the primary side it would shift the wheel over even more.. sitting on the bike its shifted to the right.
04-17-2019, 08:41 AM
Then you need to look at the wheel itself and see if it's oriented correctly. The bearing bore depth is deeper on the primary side.
04-17-2019, 08:45 AM
oriented correctly as in it rotating in the right direction? both rotors have the arrows pointing forward.
04-17-2019, 08:51 AM
Quote:
That doesn't mean the wheel is correct. The rotors were likely removed when installing the new tire.
04-17-2019, 09:02 AM
Valve stem is facing the brake side so that part is correct. Hell maybe they installed 2 spacers in the primary side,, either way its off lol
04-17-2019, 09:28 AM
As mentioned, probably the bearings (depth) are set wrong.
04-17-2019, 10:24 AM
Quote:
Agreed. If wheel is oriented correctly, then the only other explanation is the right side bearing was installed first and bottomed out in the bore.
04-17-2019, 10:32 AM
Take it back and tell them to fix the issue.
04-17-2019, 11:07 AM
Quote:
Ha evidently their solution is to buy more parts.
