Upgraded cam plate
The "issue" with that Screamin' Eagle upgrade kit is that it uses your OEM, old-style cams. While both cam tensioners are changed over to the newer hydraulic cam tensioners, only the front cam chain is switched over to the newer o-ring chain. You will still be using your OEM link chain on the cams. Many believe the link style, "silent chain" is also one of the contributors to the early demise of the spring tensioner pads...
If you are talking about changing your cam plate over to the '07+ style cam plate, you will need to buy all the specific parts (there isn't a kit available) that will include both new style roller chains, but you will also need to change out your cams to conversion cams... they fit the newer style cam plate, the older size inner cam bearings, and have sprockets for the newer o-ring chain.
In my opinion, it is not an upgrade since it leaves the inner link chain. This always rubs. The outer one will be a roller chain. It grooves in and then rolls and never wears then. About 10 years, in hot climates, the shoe can get hard.
The only way to go full roller chains is to change the cams. Hardly worth it on an 01. Cost wise, never worth it. My 04 still has originial linkchain and shoes. 50K on clock.
Replace the shoes with OEM. Check in 20-30 K for the next reference. Couple hundred. No brainer
If your bike is fuel injected if I remember from doing my 2001 Ultra that you won’t be able to use the roller chain and sprockets in the SE kit because the large sprocket doesn’t have an exciter in it for the cam sensor on 2001 EFI bikes. I had to reuse the original setup. There is a lot of opinion on using the older link chains and how much they play a part in the shoe wear. My feelings on the main factor in the shoe wear is the material and the fact that the spring style had a constant max or high tension on the chain because nothing varied for demand on chain tension so it was always putting a lot of tension even at idle. The hydraulic setup varies pressure with oil pressure so it’a Not always hammering the shoes into the chain under low RPM’s. That’s just my worthless 2 cents though lol.
