Found a 1.8kw starter that says it’s 1.25” longer. Has anyone installed a 1.8 kw starter on a 2003 road king. Looks like I will need to mod the oil fill to install it. Thanks
Many have reported that thicker wires allow the stock starter to work better. Do you have plans to use thicker wires to support the 1.8Kw starter?
I doubt the increased guage makes a difference on such a short run, and such short duration. I suspect this is a case of a little knowledge is dangerous.
