How To Adjust Driving Lights
Received 47,784 Likes
After I installed the CVO/2014 style highway lights I took it to my dealer to see if they would help me adjust mine. The mechanic placed one hand behind the light to protect the paint and with his other he formed a fist and lightly hammered the light back until it was were he said it need it to be. I tried it when I got home and it has worked for me since. Manually trying to move them just didn't work, and after they were set they don't move. Couldn't see making or buying a tool after seeing that trick?
I have a set of Craftsman Maxx Access ratchets & sockets which have a hole thru the middle of them for long bolts...I also installed a quick disconnect in the wires leading to the lights to where they normally are inside the fairing, give them a pull and they come out to where you can get to them...and I just use the Maxx Access socket and ratchet on the nut, loosen it, adjust the light, tighten it back down, and readjust as needed. Reconnect the wire. Easy peasy. No special socket required, since I already had the Maxx Access set.
I made a template out of 1/4" plywood with holes laid out to match the bolt pattern for the turn signal mounts, and a keyhole type opening to accommodate slipping over the wires and providing an opening for the socket to reach the nut. I remove the lower turn signal housings, loosen the lock nut and bolt the template to the mounts with the existing bolts. This keeps the bottom mounts parallel with each other and fixed in that position. I can then aim the lights where I want them to go. I can snug up and tighten the nuts with the template still in place without any hassle. Then I remove the template and remount the turn signals. A bit of a project at first, but I have it for future use and as a loaner.
Passing light specs
Does anyone know what the measurements are supposed to be for proper passing lamp alignment in relation to Headlamp position? right lamp ? inches up and ? inches to right? Left Lamp ? inches down and ? inches right Thanks... I don't think it matters but this is a 2007 Roadster/Sportster
I'm not sure I believe the cross-eyed theory, about one being beam being high and the other one low. I've joked for years that these lights mysteriously appear on the build line, pre-assembled - but nobody knows where they come from or why they point as they do! While the grip-and-fist may work, to redirect them, I have an old deep-offset ring-wrench which I cut a slot in, to fit over the wire and slacken/tighten the mounting nut. Snap-on I believe make a dedicated modified socket, but it's cheaper to buy and modify a ring-wrench.
