connecting rod Blueing
Bike: '99 fxds Twin Cam
Mileage: 17,500
I brought my bottom end to a mechanic to have it assembled and he noticed blueing on the connecting rods and was concerned about the longevity of them and going through the trouble of building the engine to only have to tear down again if the rods bind. I was curious if anybody on here has experience with this issue and if my only option at this point is to buy a new flywheel set up (my crank has already been welded). I checked the rod side play it was at .011 which is in tolerance what else should I check relative to the rods?
Mileage: 17,500
The guy I was originally working with on the build had a contact for the crank work, I wasn't in direct communication unfortunately and there was a falling out with that mechanic. At this point I just want my bike back together properly, hoping this doesn't become expensive. Going to call more shops for opinions.
That rod got pretty hot to turn blue. You'll probably get your question answered properly if you pose the question in the Engine Mechanical section here --- https://www.hdforums.com/forum/engin...cal-topics-46/
wesfxd (05-23-2019)
wesfxd (05-24-2019)
