Fork plug seized and unremovable
lp (06-10-2019)
Received 2,524 Likes
Thanks for the info, May try the aerokroil, tried 3 in 1, and wd40, and a torch. Back and forth, as stated before, is very limited 1 thread, max, 1.5. I’m thinking there must be a burr in those threads locking it up. Really pisses me off that this is straight from the factory like this. Oh well.
Just gonna try that “work smarter not harder” thing and see how that works out. LOL
No way to remove springs from the bottom. You can remove the slider and drain the oil, but bottom of tube has small hole for dampener rod and that’s all.
Pull the tube out of the triple. Grab the flats in a good bench vise, tube sticking straight up. Brace the tube with one hand, pull on a humongous pipe wrench with the other.
Else grap the tube in the vise, use the biggest open-end that will fit, and pound on the far end of the wrench with a singlejack. Sumthin gotta give.
Done it both ways on a bad day.
