Coolant change
Old Jun 29, 2019 | 03:08 PM
bdtaylor1979's Avatar
bdtaylor1979
I did the coolant fluid again and did it like the manual says and got between 3/4-1 quart out. More than last time but not the 1.1 quarts the manual says. I let the fans run for 5 minutes to bleed the air out.
Old Jun 29, 2019 | 03:29 PM
hardheaded's Avatar
hardheaded
Check your coolant level often after changing as you will have to add coolant a few times while it burps the air out.
Old Jun 29, 2019 | 06:02 PM
bdtaylor1979
I will keep an eye on it. Thank you
Coastal CVO
Jun 5, 2013 03:30 PM
whataboutbob
Jun 9, 2012 09:11 PM
SaltyHawg
Mar 18, 2010 09:55 AM
panamoncreel
Nov 8, 2006 09:40 AM
Bruinx9
Sep 27, 2006 12:37 AM
