Going to look at a 2009 Ultra Classic - Problems?
Looking at a 2009 Ultra Classic tonight. It's a 1 owner with 32K on the clock. He did several upgrades from the dealer before he even got it from them new. Upgraded it to a 103, added true dual exhaust, upgraded air intake, fuel management etc. He never rode it as a 96 from the day he got it.
A couple of questions:
With the engine at 32K on the clock, when should I consider checking the cam chain tensioners? How long are they typically lasting?
I have read that the compensators on the '08's and above have been a problem. With the mileage on the bike, could I assume that problem should already arose by now? I am going to ask him anyway.
Any other things I should be aware of or things I should look at?
Wheel bearings can be an issue, plan for a replacement set each tyre change.
Also make sure brake fluid is changed when moisture is >2% (Harley recommend 2 years) to avoid ABS pump problems. Harley use their digicheck computer at the dealership to move the fluid out off the abs unit.
It's recommended steering neck bearings are checked/adjust around 25k...ask if that has been done.
Moe horowetz (07-17-2020)
Check out the 5th gear whine
Gears are different in 07-09. Be sure to get in 5th gear and be able to live with whine sound. Some bikes are worse than others. Mine and many others are very annoying.
[QUOTE=grubsie;18368533]Looking at a 2009 Ultra Classic tonight. It's a 1 owner with 32K on the clock. He did several upgrades from the dealer before he even got it from them new. Upgraded it to a 103, added true dual exhaust, upgraded air intake, fuel management etc. He never rode it as a 96 from the day he got it.
The following 3 users liked this post by kojak:
Check the date codes on the tires just to be sure. Other than that, no problems on the cam tensioners. They are the hydraulic and will go 100,000 miles easy. Compensator may be an issue later but nothing that will leave you stranded. The one in my 08 RKC made it 70,000 miles before I changed it.
As another already mentioned, if you like it, like the price, buy it and ride the crap out of it. Fix it if it breaks.
