FAG's?
The HD branded wheel bearings are manufactured in South Korea, which leads me to believe they are the FAG brand by Schaeffler Korea. Does anyone here know if this is true? If so, they are reputed to be of a very high quality matching other name brands such as SKF.
https://cimg7.ibsrv.net/gimg/www.hdf...9fe4b02f3c.jpg |
Fooled me, thought this was going to be an import bike thread... Thanks for the post, I am following this one.
I have used FAG bearings in the past on trucks, no issues.
While I have no idea if the make the HD bearings, I do know that 1 rear OEM bearing fail at 12K. Not burnt up yet, just noisy and a bit gritty. I thought you went the SKF route last month? |
Originally Posted by NorthWestern
(Post 20709210)
I know for sure the original 9252 encoder side bearings on my ‘14 Limited were FAG Canada. That’s all I got.
Originally Posted by GalvTexGuy
(Post 20709308)
Originally Posted by 702
(Post 20709873)
Was the bearing marked with an identifier?
That leaves little doubt, thanks!
I guess all I had to do was open the package. The ABS bearing is marked, but the non-ABS bearing isn't. Since they both come from South Korea that's enough evidence for me.
https://cimg6.ibsrv.net/gimg/www.hdf...7163151222.jpg |
(Post 20709991)
https://cimg0.ibsrv.net/gimg/www.hdf...1f1f1e919.jpeg |
| All times are GMT -5. The time now is 08:28 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
