Whats up with this 2007 crankshaft problem?
RE: Whats up with this 2007 crankshaft problem?
Ill bite and say that once in a while I notice the clutch lever snapping back on decel. I thought maybe it was me losing my mind, but maybe not. Any chance its torque loading on the engine mounts and pushing on the cable under load, and releasing when letting off the throttle? Curious if this happens on softails or dynas.
I've never noticed it but will try to remember to look next time I'm out. My guess is it's got to do with the mainshaft thrusting on the helical-cut gears. I'm also thinking since in 6th the power's not leaving the mainshaft that it won't do it in that gear.
I seem to remember an article by Donny Peterson in American Iron. He said that all the helical gear teeth point on one direction and this loads the torque in one direction and when you decel it moves the clutch lever. Don't know how bad this as this is all I remember. I have to see if I still have that issue. As for the cranks my local dealer tech said they see alot of cranks with runnout more than spec. like .002 to .004. Doesn't seem like HDs quality control is where it should be.
ORIGINAL: 211Chuck
#2 My clutch lever would pop out to the mounting pertch when I closed the throttle from day one also.
