fuel pump priming question...
Old Jun 25, 2023 | 10:24 AM
memphisharley's Avatar
memphisharley
Default fuel pump priming question...
if I turn the ignition switch on and off multiple times with the run switch on should i hear the fuel pump prime each time. right now when I do this in succession it on ly primes on the first turn on. I'm turning it on for 10 seconds then off for 10 seconds 5 times.
thanks
Old Jun 25, 2023 | 10:30 AM
jp0469's Avatar
jp0469
Sounds normal since there's already enough pressure in the fuel system from the first prime.
Old Jun 25, 2023 | 10:33 AM
Rusty Springs's Avatar
Rusty Springs
There's a delay. I don't know exactly how long but what you describe is normal.
Old Jun 25, 2023 | 05:08 PM
Dseago1969's Avatar
Dseago1969
Is there an issue or is the bike running ok?
Don’t turn it on and off for ten seconds 5 times in a row, problem solved.
But, it is different depending on year and maybe some other things. I went out and tested on both of my bikes. 2011 Road King Classic and also a 2021 Road Glide Standard. The Road King has been flashed with a PV5 when I did stage 2, not sure if that matters.
2021 primes every time the switch is turned regardless of time.
2011 primes again after about 5 seconds, remember the ECM has been flashed.
The older Delphi ECMs originally had a 10 second timeout on the prime, I think it is stated in a service manual but mine for the 2011 is still packed in a box in the basement. If it is running fine, no worries.
Old Jun 25, 2023 | 06:12 PM
memphisharley
thanks guys.
had a PO1511 and PO 2135
Old Jun 25, 2023 | 07:25 PM
Dseago1969's Avatar
Dseago1969
I’m pretty sure those are throttle control codes.
Old Jun 26, 2023 | 11:17 AM
Max Headflow's Avatar
Max Headflow
You'll probably need to wait up to 20/30 seconds for the micro in the ECM to go to sleep. On some bikes, you can tell as the speedo and tach needles twitch..
Old Jun 27, 2023 | 06:41 AM
memphisharley
yes they are. tps correlation issue.
yes..it primes when I give it ~30 seconds.
Old Jun 27, 2023 | 10:13 AM
jake24lt's Avatar
jake24lt
"I told my Doctor, it hurts when I do this!"
Doctor says, don't do that !
King Hit
Apr 22, 2023 09:55 PM
Daniel99314
Feb 24, 2023 03:24 AM
crabby_sportster
Sep 26, 2017 08:13 AM
shiltpold
Nov 3, 2013 03:14 PM
boone432
Mar 21, 2008 10:31 PM
