2007 electra glide charging issue
Old Jun 26, 2023 | 01:50 PM
skroemer's Avatar
skroemer
Stage II
Default 2007 electra glide charging issue
So my bike tells me it is overcharging. Voltmeter reads15vdc. Followed the troubleshooting on the forums. Everything seemed normal, changed regulator just in case. Checked voltage at battery and it reads 14.08. Could this be a bad gauge?
Old Jun 26, 2023 | 01:54 PM
MURPHCC1's Avatar
MURPHCC1
Are you reading the voltage on the dash gauge?
NOTORIOUSLY INACCURATE!!
But check for codes.
Old Jun 26, 2023 | 02:31 PM
WP50's Avatar
WP50
14.08 at battery your plenty good to go.Very few dash volt gauges are on the money
WP
Old Jun 26, 2023 | 04:00 PM
Baird's Avatar
Baird
Voltmeter is the only gauge that can be adjusted, read with a decent digital meter and adjust the screw on the side to match. Pain to get at, but at least once adjusted you're in the ballpark.
Old Jun 26, 2023 | 06:51 PM
im's Avatar
im
Welcome to forum.
Sometimes what seems very simple can actually be more complex and it really requires information in order to obtain a useful answer.
What bike?
What year?
What changes from factory stock?
How many miles?
History of ownership.
You state "Voltmeter reads15vdc." was that at battery? was that at rest? while cranking? at high idle?
You state "Everything seemed normal"...what does that mean to you?
You state "changed regulator just in case". Why did you change an untested or unconfirmed part? What regulator brand did you use to replace?
The replacement of unconfirmed parts can sometimes complicate diagnostics.
You state "Checked voltage at battery and it reads 14.08. Could this be a bad gauge?" Tested with what?
Old Jun 26, 2023 | 06:57 PM
Rounders's Avatar
Rounders
Use a voltmeter on the battery,if you are not, should be around 14.4 reved up.
Do you have bulbs burning out? Black inside? I am told can be sign of high voltage.
Sounds ok to me. Maybe was hig and you fixed it. Either way volt regs are weak links, and you replaced one 16 years old
Old Jun 27, 2023 | 08:04 PM
skroemer's Avatar
skroemer
Stage II
Thank you everyone, I appreciate all the help! I didn't know the voltage gauge was adjustable. The previous owner left me a couple problems to fix. All in a days work! Everybody be safe!
Frogprince
Apr 9, 2024 10:08 AM
Pkman
Apr 14, 2019 07:28 PM
RideFree1267
Electrical/Lighting/Alarm
Nov 28, 2017 05:05 PM
Mikethebiker
Aug 19, 2014 02:55 PM
madwig
Mar 22, 2013 01:26 PM
