Maintenance Schedule - Major
Old Sep 4, 2007 | 05:43 AM
kevinrlbd's Avatar
kevinrlbd
Stage II
Default Maintenance Schedule - Major
Okay guys thinking about buying an '08 Ultra, one thing keeping me from pulling the trigger is engine maintenance and thestories surrounding reliability.
So what do these engines need as they get older? Run an average of 15K per year, two up, towing a trailer for more than half those miles.
Thanks, Kevin
Old Sep 4, 2007 | 06:01 AM
Blackisfast's Avatar
Blackisfast
Default RE: Maintenance Schedule - Major
'08 maintenance history so far is limited to about 2 months, eh?
There's no way to tell what difference the changes they made will eventually show...
Old Sep 4, 2007 | 06:32 AM
kevinrlbd's Avatar
kevinrlbd
Stage II
Wasn't looking for '08 info as much as say '06 & '07's that have some miles on the motors as well as older Ultra's.
Kevin
Old Sep 4, 2007 | 06:37 AM
BillyO's Avatar
BillyO
Go buy an 06 TC88 and put Big Bore Kit Stage Two and have NO issues.
Mine is a delight to ride.God it is a nice bike.
Old Sep 4, 2007 | 06:49 AM
Retired_Ted's Avatar
Retired_Ted
ORIGINAL: kevinrlbd
Thanks, Kevin
After working in a HD shop for the past year, I feel I can give some honest data regarding longevety and maintenance of the TC88/96. First off, it's an air cooled engine at the mercy of ambient air for cooling. The engine goes through many hot/cold cycles and, therefore, may be subject to forces that aren't quite as extreme as a water cooled engine. Gaskets seem to a major weak point - especially the transmission output gasket and primary gasket area. We see more leaks in that area than any other. Valve cover gaskets are next. Vibration is the next engine "killer". The constant shaking takes its toll in almost every area of the bike - bolts work loose, nuts fall off, etc. Third major area of concern is the charging system - the stator is subject to the same temperature extremes as are the gaskets. The regulator is suposed to be kept cool and many guys will cover it with a shiney piece of chrome which will cause a regulator to eventually fail. I found it unusual to see a HD with more than 30K on it that didn't show a lot of weathering on areas that should have held up better - HD still hasn't discovered stainless steel fasteners. Head bolts corrode and look awful after a couple of years. Covering them with chrome helps, but, also traps moisture and can make the corrosion process accelerate. These are a few of my observations after working in the shop for a year as a service writer, not a mechanic. The mechanics, however, will agree with me, I believe. If you want to hear the HD sound, you'll put up with these problems - if you want longevity, power, ease of maintenance, and reliability - you'll look somewhere else. Let the flames begin .
RAWHD
Mar 21, 2016 10:55 PM
hrchdog
Jun 1, 2008 10:13 AM
wvr1sxh
Screamin Eagle CVO Models
41
Apr 4, 2008 12:08 AM
ZJAvy
Jan 21, 2008 11:25 PM
hawg50
Aug 8, 2007 12:03 PM
