FYI: This $35 mod is on my to-do list for the spring.https://stealthport.myshopify.com/pr...-charging-port
There are a few YouTubes showing installation. Briefly, with the "top mount" kit you extend the existing tender cable to be mounted up top between the left bag and the seat.
See
There is another thread on here about the Stealthport. Per recommendations I installed their Midframe Air Deflector mount on my 2022 Road Glide Limited. Easy install and the plug is easy to get to while being completely concealed, good luck.
On my 2023 U.L. I zip tied it to the top left saddlebag guard because on those rare occasions when I use my heated vest I plug it in there. Easy to access while sitting on the bike for the vest, easy access to plug the tender into.
Good idea, thanks. For now, I just ran it out the bottom and even used the notch the molded into the plastic backing plate (or whatever it's called). I will move it somewhere more convenient and inconspicuous.
