How do you remove bug juice from fairing?
Anyone ever try WD-40?
May sound silly but it works wonders on bug juice. It has a Kerosene basein it.(that's also why you should never use it as a lubricant)
It also works great on road tar. I've never had any paint issues with it but I do clean it off and quick wax after.
Enjoy --> Reksul
Plexus and Honda cleaner are not the same....careful with the Pledge around you seat, can discolor your seat, Honda cleaner works great on you seat, doesn't make it slick like Armour All....[sm=smiley20.gif]
I have found another product call Pro Wash, comes in a 16oz bottle and mixes with water, makes a gallon....good stuff, but not as good a Honda Spray Cleaner.....
Also, if you like using products such as Maguires or other type cleaner and don't want to take a large bottle on trips, find a lady friend that goes to or knows someone that attends those "Pampered Chef" parties, have them get you a turkey baster...a little bottle with a pump top. Fill the bottle with your favorite cleaner, pump the top and it creates pressure inside, use it like a spray bottle, when finished, open the top a little and the pressure is released, pack away in tourpac or bags. Works like a charm...[sm=smiley2.gif]
However, Kawasaki seems to have either directly copied or even purchased the rights to the orignial Honda Cleaner secret sauce, because the stuff now sold at Kawasaki dealers- KawiClean, is the exact replacement for the original Honda Cleaner, heck it even smells the same. So be very careful.
One other trick I learned many moons ago when I worked part time at a local airport was to mix some baking powder in hot water, works wonders at neutralizing the bug juice acid and helps it come off much easier.
I recently changed from regular Pledge to the new multi-surface version, works even better...one shot and a swipe with a micro fireb, clean and shiney.
Lemon Pledge and micro fiber cloth. works like a dream. even pack a can to use on the road at fuel stops.
