Anyone have Andrews TW26 cams?
RE: Anyone have Andrews TW26 cams?
If you go 95", stock heads, and the 26 cams..............you'll probably be around 85-90 on both hp and torque. And if you are going to do the 95", you might as well send your heads off to be ported/polished and have them cc'ed and milled for equal compression and bump it up a bit also. Check out www.bigboyzcycles.com and give Bean a call..............he'll do your heads for $395 and bore your cylinders for $130 to accept the SE flattops, he can also supply you with the Cometic .030 head gaskets.
Steve
Steve
Hi Steve,
Bangor's gettinga chilly ride in the mornings. I'm trading my 06 RK for an 08 Ultra.The new 96" motors don't seem to put out likean 88" w/ the big bore kits and 203 cams. I'm wonderingabout how to get the most umph for the buck without knocking my mileage intothe dirt.
Considering a 103" kit for about $1500. Suggestions?
Thanks, Bud
Thanks, Bud
