FAIRING DEBATE
Old Oct 22, 2007 | 10:06 PM
stevepacman's Avatar
stevepacman
Default RE: FAIRING DEBATE
I'm starting to lean toward the DragonFly. Thelines do look cleaner than the Quadzilla.
Rico,
Thanks for all the detailed info! Another couple of questions: Does the radio have a weather door? Did your wheels raise your ride height? My RKC is dropped 1 1/2" from stock with Progressive Suspension components. I have a short inseam, so any height increase would be a show-stopper for the wheels.
Old Oct 23, 2007 | 10:48 AM
Hagar the Horrible's Avatar
Hagar the Horrible
I have a slighlty damaged Quadzilla for sale. Since you gotta take it to the painter anyway, what's a little body work. $799 It has a big clear windshieldand the eclipse stereo CD, 4 speakers (plays fine)
If your reading this now the fairing has been sold!
Old Oct 23, 2007 | 04:54 PM
Rico450r's Avatar
Rico450r
ORIGINAL: stevepacman
Rico,
Yes there is a weather door on the radio that slides open and close to wash the fairing. You really can't notice the difference with the 21" wheels. You know it's a bit higher but yet you can't tell by riding. I'm thinking of just leaving it alone because the change wasntthat noticable. You should be fine. Also HD does make spring kits to lower your bike that half inch. I wouldn't let that be your decision. My wheels attract so much attention. Good luck
Rico
Old Oct 23, 2007 | 05:19 PM
stevepacman
Thanks to everyone for the feedback. I'm saving my pennies now : )
Old Oct 25, 2007 | 02:04 PM
wjoel's Avatar
wjoel
Stage II
Hey there from Dead Center Cycles. It's great to see that these conversations seem to be getting more and more common! I just wanted to clarify a couple of things that came up in regards to the Dead Center Fairing. While we do not have a "sealed" stereo box we do install a drip guard above and a splash guard below the stereo compartment. This configuration allows for easy access when adding amps or satellite radio, effectively prevents rain from getting into the fairing via deflection off of the nacelle and directs any moisture that may enter from above around the stereo compartment and out the bottom of the fairing.
The locking michanism actually wraps entirely around the quick detachpost making it necessary to pull the entire mount to remove it. A person could not just undo the nuts and take it off.
Good luck Steve!
Old Oct 25, 2007 | 03:35 PM
JTE2518's Avatar
JTE2518
Does any one know anything about (wideopencustoms) look really good.I put on a amp.speaker system but if just does not get it at 65mph..
Old Oct 25, 2007 | 03:44 PM
Hagar the Horrible
Wide open fairings are made of plastic, not fiberglass. Sold without stereo.
Firebagger makes a nice looking locking unit similar to DCCand resonably priced,but I havecontacted them and they have yet to respond.
Old Oct 25, 2007 | 03:51 PM
dirtnap664's Avatar
dirtnap664
I chose the Quadzilla fairing and have had no problems. Absolutely love it and it was worth every penny. Stereo is plenty loud at any speed and as far as not locking, I don't see a problem with it. You'd have to undo the nuts for the passing lights to pull it off.
Old Oct 25, 2007 | 04:06 PM
JTE2518's Avatar
JTE2518
Wide open shows with/with out stereo. wouldn't plastic be lighter.
http://wideopencustom.com
Old Oct 27, 2007 | 12:47 PM
stevepacman
I'm sure the ABS is lighter. The only things I don't care for are the brushed look of the mounting brackets and the cheap looking weather-strip along the base of the windshield. Even though it is less expensive at $799 with stereo (no paint available),the cheezy rubber strip pretty much knocks this one out of the running.
