Front rotor replacement
Old Dec 22, 2005 | 10:21 AM
lowleveldriver's Avatar
lowleveldriver
Default Front rotor replacement
Has anyone replaced the front rotors with the polished chrome rotors? If so do you need any special tools? Or should this be one for the dealer?
Old Dec 22, 2005 | 10:26 AM
HDF Tech's Avatar
HDF Tech
Default RE: Front rotor replacement
You can do it, as long as you have the manual to back you up and the tools necessary along with a lift. You will have to use a small tourch like a benzomatic to heat up the rotor bolts as they have red loctite on them and if not heated, they sometimes strip the head trying to remove them, also reapply thr red loctite when you reassemble the rotors. It's not a difficult job, just a little time is required but a good way to get to know your bike. Just follow the manual and use a torque wrench for the fastners. Double check everything as you do it and you'll be fine.
Here's a tip https://www.hdforums.com/m_190154/tm.htm
Old Dec 22, 2005 | 10:35 AM
lowleveldriver
Thanks TC
Old Dec 22, 2005 | 10:50 AM
coolharley's Avatar
coolharley
I have taken front and rear rotors off my last bike (Night Train). I had buffed and painted my rotors with a high temp black paint, which turned out awesome.
Hardest part was getting those darn torx bolts loose - had to vist a buddy's garage and use air wrench for the back rotor. But its nothing complex, good project to undertake if you have time and interest. As mentioned earlier, a bike lift is definately needed.
Don't forget to toss the old ugly bolts and get the nice chome rotor bolts!
Old Dec 22, 2005 | 11:52 AM
lil_gmac2's Avatar
lil_gmac2
Keep us posted on how it turn out for you. I'm not handy so I just go to the bike shop.
Jake911
Jun 9, 2013 09:19 PM
ggrif
Jan 10, 2012 05:06 PM
BlackFLHR
Oct 23, 2009 08:11 PM
LiveLifeLarge
Mar 9, 2009 06:48 PM
UGGA
Oct 5, 2006 12:34 PM
