"DIY MODS" and TRICKS to SAVE $$$$$$
#1002
#1003
#1005
Gauge / thickness of shim?
What's causing the rattle? I can't find where the shield is hitting the pipe anywhere. I get the shims will step the shield away from the pipe if I am understanding what you want me to do correctly.
Is the desired use of the shims to step the shield away from the pipe or to act as a bushing between the pipe and heat shield loop?
Forgive me, it's late and I barely have one eye open.
#1006
Location: Western Illinois, land of bad roads, and corrupt politicians
Get a chunk of exhaust pipe, and cut out some 1/2 round by 1 inch pieces. This will give the clamps some more grab, and also move the shields away from the pipe.
Or you could buy new clamps
#1008
#1009
The guy in the video used magnets with 12 lbs of pulling force, that seems like it would over power the magnetic plugs in the oil pan and the primary and prevent the metal shavings from attaching to them. If you had this:http://www.kjmagnetics.comproddetail.asp?prod=BCC8E epoxy coated magnet that pulls 34 lbs where would you place it, maybe on the swing arm? I'm wondering how far the magnetic field reaches, anyone have some thoughts on that?
