Broken Fender Struts
Old Dec 30, 2007 | 09:16 PM
MajorJim's Avatar
MajorJim
Default Broken Fender Struts
I have an 05' Roadking Custom with 48,000 miles. Twice now my fender struts and bottom support that goes from side to side have broken. Has anybody else out there had this problem? Also my rear header pipe has broken four times. The last time I replaced the exhaust with V&H dresser duals.
Old Dec 31, 2007 | 12:01 AM
harleyflo's Avatar
harleyflo
Default RE: Broken Fender Struts
my friend as the same bikeand he changed is twice with less mileage.(struts)
Old Dec 31, 2007 | 04:56 AM
Duracell's Avatar
Duracell
Stop lifting the front wheel
Old Dec 31, 2007 | 10:49 AM
gordo 2050's Avatar
gordo 2050
My neighbor has the same bike, and we just realized his left side is broken as well. 13,000 mi.
Maybe a factory defect that should be covered?
Old Oct 10, 2008 | 07:32 PM
oha2kan's Avatar
oha2kan
6th Gear
79000 on my 2003 Road King. I have replaced struts on both sides twice. Cracks right at where the piece bends out. No one can give me an answer. Harley Parts man says that is why we sell them!!!!!!!!!!!!!!!!!!!!!!!!!!
Rear pipe on mine broke three times. I went to VnH Pro Pipel...
Old Oct 10, 2008 | 07:36 PM
Neckball's Avatar
Neckball
You mean like this?
Old Oct 10, 2008 | 07:42 PM
nastyHD's Avatar
nastyHD
My left side also broke around 22,000 miles, I looked around and got a great deal on a set off eBay... so I replaced both of them just to be safe
Old Oct 10, 2008 | 08:00 PM
vindyl's Avatar
vindyl
usually happens when you remove the rear bumper on egs not sure why it happens on a road king
Old Oct 10, 2008 | 10:22 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
That's not good.
Old Oct 10, 2008 | 10:35 PM
planewrench's Avatar
planewrench
I noticed when I removed the struts to change the rear fender on my '07 RKC that the tabs,(the part that breaks off), were not bent a full 90 degrees for proper alignment. When I went to reassemble everything, I could see the strain it put on the tabs as I tightened the bolts. I wound up bending the tabs so that all the bits and pieces lined up upon reassembly without the bolts having to pull everything into submission. Don't really know if this helped, but it made me feel better.
TexFF
Sep 10, 2015 01:38 PM
Wabbit
Mar 13, 2015 12:55 PM
RelentlessConviction
Dec 6, 2010 04:08 PM
zoood
21
Feb 15, 2010 04:53 AM
NCTURBOS
Feb 17, 2009 01:21 PM
