Detach tour pack to remove the tour pack
We ordered 2008 FLHTCU which will arrive in El Paso in June 2008. We have asked the parts department regarding the removal of the detachable tour pack for our FLHTCU. We were told that there was not a detachable kit for the 2007-2008FLHTCU models. Do you know of anyone or anywhere where we can get an answer to this request?
RE: Detach tour pack to remove the tour pack
53276-04
Fits '97-later Road KingĀ®, FLHT, FLHX and FLTR models equipped with required docking hardware. FLTR and FLHX models require Antenna Relocation Kit P/N 76326-00A. Does not fit with Layback License Plate Mounting Kit P/N 53385-00. Some EU registration plates may interfere with Tour-PakĀ® Rack. Models wtih rear fender tip trim can be adapted with seperate purchase of License Plate Relocation Kit P/N 60095-00A.
The reason Harleys say they don't make a kit is because of the wires going into the TP. They don't have a waring harness for it that is quick disconnect. Buy the TP relocation kit for a Classic, buy the antenna relocation kit. Then buy some quick disconnects for the wires. You will have to slice in the wiring harness disconnect yourself
I move the antenna from the TP to the relocated mount each time I take off the TP
I have it on my 2007, don't know what any of you are talking about!
Relocated my antenna into the fairing, powered model. It works much better than a little one at the bumper.
I just have to plug in the tour pack lights and the rear speakers. There IS a plug for both.
U
U
ORIGINAL: Richpend
53303-07 $329.95 MSRP Detachable our pack rack kit (comes with rack, docking hardware, antenna relocation kit and chrome license plate holder) or if you want to go with the antenna wire in the fairing you can use part # 53276-04 $179.95 with docking kit # 53804-06 $54.95 and buy yourself a laydown license plate holder part # 113 from Kuryakyn $39.99.
All the antenna's, tour pack lights and rear speakers can be disconnected and rolled up abd stored under the seat.
I had mine done at the dealer.
53276-04 2-up detachable tour-pak rack 214.95
53804-06 Kit, docking hardware 64.95
53376-97 (used part) Licence plate holder 10.00
They also used a few wire connectors.
Had my radio ant. put into the faring (hidden one) 100.00
ORIGINAL: Ultra007
Is that true (I haven't checked it yet) ?
I sort of looked for a dis-connect plug for the tour pack lights but haven't seen any.
Where is it located ?
Thanks ...
Rob .....
