DYNO Numbers for Baggers???
  #5001
Old 06-01-2015, 09:37 AM
Pepper1's Avatar
Pepper1
Pepper1 is offline
Originally Posted by sporacer
According to your dyno sheet you start off about 13.5 then the bike gets leaner not richer. Im not a fan of any piggy back tuners. I prefer tts. Keep searching for a tuning center. even if you have to drive 8 hours its worth it.
Thanks for the advice! Pardon my ignorance, but what is tts? Is that a brand?
  #5002
Old 06-01-2015, 10:13 AM
sporacer's Avatar
sporacer
sporacer is offline
yes TTS is a brand of tuner. it overwrites your factory software and is very trouble free.
  #5003
Old 06-01-2015, 10:26 AM
Joker65's Avatar
Joker65
Joker65 is offline
And do it sooner rather than later, before the temps get too much hotter! Any tuner worth a damn would/should know what AFR to be running at!
  #5004
Old 06-01-2015, 10:35 AM
Pepper1's Avatar
Pepper1
Pepper1 is offline
Is there a baseline for AFR? Do you have to use the O2 sensors with the tts?
  #5005
Old 06-02-2015, 10:18 AM
Keithhu's Avatar
Keithhu
Keithhu is online now
Received 5,357 Likes on 2,614 Posts
Keep in mind that the dyno chart shows whats happening at WOT. It gives you exactly zero information about whats happening at say, 30% throttle.
Since we presumably dont spend much time at WOT, you'd have to look at the map settings to understand whats going on during normal riding conditions.
  #5006
Old 06-02-2015, 07:04 PM
Hate Work's Avatar
Hate Work
Hate Work is offline
Default Isn't that what dyno is doing?
Isn't the dyno to "simulate" what is going on at, let's say, 30, 40, 50% throttle? And if it isn't, what am I missing?
  #5007
Old 06-02-2015, 08:57 PM
Keithhu's Avatar
Keithhu
Nope, its WOT. In only 1 gear. 4th, 5th or 6th. Usually 5th if I'm not mistaken, but the charts dont tell you that either.
If you think about it, it would have to be 3 dimensional to show what you're asking.
  #5008
Old 06-03-2015, 06:22 AM
tjwallib's Avatar
tjwallib
tjwallib is offline
5th Gear
The dyno sheets that are posted here are Wide Open Throttle,,,,,but if the person doing the tuning is worth their salt,,,,,,they will be tuning the bike across the full range of throttle and engine load conditions,,,,,,Unfortunately that isn't always the case, and a lot of "tunes" are just done for Wide Open Throttle.
From the dyno sheets posted, there is no way to determine what is going on with AFR values across anything other than WOT.
Looking at the MAP settings MAY tell you what is going on in the bike at partial throttle settings,,,,,,,depending on how competent and thorough the tuner was.
  #5009
Old 06-03-2015, 05:59 PM
harleytuner's Avatar
harleytuner
harleytuner is offline
This is true.the thing to remember though is that the wide open throttle part of the tune is the easiest to dial in. So it's a pretty good bet that if the guy tun ok ng the bike can't tune the easiest part chances are the rest of the tune sucks as well.
  #5010
Old 06-04-2015, 07:31 PM
greggg's Avatar
greggg
greggg is offline
Smile 2012 RKC Dyno
Tmann tr 600 cams .030 headgasket, power vision tuner, SE pushrods, headjob, 2009 headpipe,V&H slipones
Quick Reply: DYNO Numbers for Baggers???
