DYNO Numbers for Baggers???
#5551
This is not so much HP orientated mapped but for as much torque as possible. Its good for me but not the winner for performance enthusiasts. For me the most important objective is to gainas early as possible max values necause the max rpm I run is about 4000. All the best heiko
#5552
I agree, the scaling is all wrong. The vertical NM scale for torque is out of kilter, that should be much further up the paper and closer to the power curve.
#5553
Its just a different kind of diagram...
Hello, the dotted line is torque. The Nm means newton metres torque. PS means HP. Umin means rpm.
so, my bike has 156 Nm torque and 92 HP wheel performance 6th gear. Thats at least what the dyno said while I was there and what you see is the pdf of the printout I got.
we used the power vision to optimize the fuel / air ratio and eliminated the harley tunes. Ignition, timing etc is changed to 100 octane fuel we have in germany.
Most important for me was to get max torque/hp performace before 4000rpm.
all the best
heiko
all the best
heiko
#5554
all the best
heiko
all the best
heiko
#5555
100 Octane
You have 100 Octane fuel in Germany? Is that for everyone? We have it here but it's $9 a gallon....sometimes I'll throw 1 gallon into a 6 gallon tank, but I'm not paying $54 to fill up a 6 gallon tank and we don't have to...these bikes run great on the 93 octane around here...
all the best
heiko
all the best
heiko
#5556
#5557
100 Octane fuel!
Yes, to companies supplying superfuel.
1. Shell V Power 100
2. Aral 102 octane
Between 5 and 15 € e cent more expensive to super 98 octane. Std super has 95 octane in Europe.
Does it help? I dont know. All I know the engine runs smooth and better compared with 95 octane fuel containing 10% green alcohol. 95 burns hotter what we dont want.
I eliminated the oxigene sensors and keep a stable 13,4 air fuel ratio instead of 14.6 +/- Harley tuned the engine to allow low exhaust temp but higher co rates.
all the best
heiko
2. Aral 102 octane
all the best
heiko
#5558
Courtesy of Wikipedia:
"Because of the 8 to 12 octane number difference between RON and MON noted above, the AKI shown in Canada and the United States is 4 to 6 octane numbers lower than elsewhere in the world for the same fuel."
So German 100 octane is roughly equivilent to US 94 octane - not enough difference from 93 to get excited about!
#5560
Finished up my winter/spring upgrades.
2005 CVO Screamin' Eagle Electra Glide
120R Based
Stock Cases
S&S 120R Flywheels
110 heads by Jim@ Mega-flo
SE 4.060 cylinders
SE Hurricane pistons
S&S 66mm cable drive Throttle Hog
Stealth backing plate with 1" taller filter
Head Quarters 0037 cams
Fat Baggers 2-1
11.5 compression
120R Based
Stock Cases
S&S 120R Flywheels
SE 4.060 cylinders
Fat Baggers 2-1
11.5 compression
