DYNO Numbers for Baggers???
#5561
Finished up my winter/spring upgrades.
2005 CVO Screamin' Eagle Electra Glide
120R Based
Stock Cases
S&S 120R Flywheels
110 heads by Jim@ Mega-flo
SE 4.060 cylinders
SE Hurricane pistons
S&S 66mm cable drive Throttle Hog
Stealth backing plate with 1" taller filter
Head Quarters 0037 cams
Fat Baggers 2-1
11.5 compression
120R Based
Stock Cases
S&S 120R Flywheels
SE 4.060 cylinders
Fat Baggers 2-1
11.5 compression
That's damn impressive. Well done!
#5562
Outside of the max HP and torque #'s I don't really know how to read the Dyno sheet. I'm hoping for some feedback on my output because I'm having issues with the bike. I have a separate thread on my issue...
2016 Road King - Rinehart Slimline Duals full exhaust, Roland Sands Turbine air cleaner
Tuned with the EPA friendly Screaming Eagle Street Tuner (black box)
#5563
The most important feature is the shape of the torque curve. As we are all riding heavy touring bikes and many of us ride 2-up with luggage, we are looking to give the giddy-up to around half a ton of man and machine. We have also got into the habit of expecting our poor engines to do that from low rpms, so high numbers in the low rpm range are good. Your curve is OK, but take a look at others in here, such as in thread #5506, with high torque early on, tailing off a little in the upper rev range, where if doesn't matter so much.
#5565
#5566
This was a build that was done 2 years ago, got almost 10,000 miles on the build. Still runs great. CVO 110, stock pistons, stock 255 cams, Rinehart True Duals, TMan Heads, S&S lifters. Tuned by Doc. Just found the Dyno sheet so I posted it. Not bad for basically a Head Swap.
#5567
#5568
#5570
