DYNO Numbers for Baggers???
#5721
I have a 09 rkc. TC 96. S&S single bore tuned induction, S&S 79 super stock heads, S&S roller rockers, quicky pushrods, performance S&S lifters, complete S&S cam chest w/551 easy start cam and Vance & Hines dresser duals with oval slip ons ,power vision w/wide band o2 sensors. I'm about to get this bike dynoed. Can anybody give me a estimate on how much torque and hp I can expect. Just trying to keep it honest.
#5722
#5723
#5724
The differences are because the STD correction factor uses standard conditions of 60F, 29.92inHg and 0% humidity which is a more favorable condition to make power than the SAE correction factor of 77F, 29.23inHg and 0% humidity ... a more "real world" condition and the most widely accepted factor. Uncorrected, of course, is the power it is making at the present conditions ... no correction factor.
There is nothing wrong with using either, but when comparing to other graphs, make sure you compare apples to apples, i.e. SAE to SAE or STD to STD.
#5725
#5726
After going through all that mathing, I saw the "CF: EEC" in the upper right corner. I'm guessing HarleyTuner, and maybe most of you, already recognized that. Does that mean that a correction factor of 1.16 (the number noted in the bottom right for the EEC) has already been applied?
#5727
To see the full thread ...
https://www.hdforums.com/forum/touri...omparison.html
... but here a a TTS vs. SEPST comparison ...
The build was done and tuned in 2013 with a SEPST and represented in "red" ...
FM 107" Big Bore Kit
CP +3 Domed Pistons (10.75:1 CR) (actual static 10.6-10.7)
TW-777 Cams
Wood Performance Directional Lifters
FM Adjustable PR's
FM Level B CNC Heads
FM Throttle Body Porting & A/C Backing Plate Match
32-Tooth to 30-Tooth Tranny Sprocket Upgrade
Goodyear-Falcon SPC 1"-139T Drive Belt
Baseline Dyno Run
Dyno Break-in
Bike already had a SEPST, V&H PD's, Bassanni's with 2-1/4" baffles and SE Heavy Breather.
Switched to a TTS tune a few weeks ago and is represented in "blue" ...
Same dyno and tuner.
Not a whole lot of peak hp and torque increase, but look at the increase of torque from 1800-3200 rpm and the steady increase of hp from 1800-3000 rpm and 3500-5800 rpm. This is definitely power you feel. It is possible some of this difference is from additional break-in and loosening of the motor, but there is definitley a significant change in ridability. Numbers are SAE corrected.
TW-777 Cams
FM Adjustable PR's
Baseline Dyno Run
Dyno Break-in
#5728
Dyno day
Off the shelf stage 5 tire shredder kit. The 10.2 lower compression "street version".
the only other performance additions to the kit are the street cannon mufflers. This is also on a stock head pipe WITH the catalytic converter still in place. Considering the compression and torque curve, I am very happy. Not much to be gained w a new pipe. So if anybody was apprehensive about using the stock head pipe w cats on a Rushmore bagger, I'll let my sheet do the talking.
This is a photo of the sheet on the PC. Couldnt leave without some proof. Should have the .pdf today or tomorrow.
#5729
I think that you can do better. My '15 Dyna with a 103 Stage I tune puts out 78 HP and 95 ft lbs of torque...
#5730
