Rider backrest on FLHRS -- removal
Old Jun 3, 2008 | 08:17 AM
jamstutz's Avatar
jamstutz
6th Gear
Default Rider backrest on FLHRS -- removal
I recently got an '04 Road King Custom that had a rider's backrest installed. I like the backrest and plan to keep it, but I need to take it off to remove the seat and access the battery. I know the rider backrest is supposed to have a quick release but I haven't found it. I obviously don't have the instruction sheet that would have come with the backrest.
It's probably simple and obvious, but I plea for mercy due to a wasted youth during the 60's...
Old Jun 3, 2008 | 08:39 AM
Jinks's Avatar
Jinks
Default RE: Rider backrest on FLHRS -- removal
Reach into the slot in the seat, grab the backrest mount & *SQUEEZE*! It's a bit of a PITA, but you squeeze the mount together & wiggle it up out of the bracket. Goes back in the same way.
Old Jun 3, 2008 | 08:52 AM
BlkSilverado's Avatar
BlkSilverado
If it's a adjustable backrest,the release is at the rear of the bracket. You need to push thebackrest forward, and then reach in andpush therelease towards the rear of the bike while removing the backrest. I'd bet your local dealer will assisit you if needed.
Old Jun 3, 2008 | 12:04 PM
jamstutz's Avatar
jamstutz
6th Gear
Thanks, guys. The one I have is the non-adjustable w/o the cable or handle. I think Jinks nailed it--I'll check when I get back home.
dh_meyer
2014-2024 Touring Models
May 20, 2015 05:56 PM
wascapsfan
Feb 12, 2014 10:39 PM
rperk60
Jul 22, 2012 08:49 AM
dragonx
Sep 27, 2007 11:46 AM
zlaneb
Oct 19, 2006 12:12 PM
