Fluid Leak between Inner Primary and Transmission
I have a 2006 Ultra Classic with 20,000 miles on it. Have noticed that after a ride I have a very slight fluid leak between the inner primary and transmission i suspect it is either or both the Main Shaft Seal or/and shifter shaft seal. How difficult is this to fix? What would the best seals be if in fact it is?
DJ
DJ
RE: Fluid Leak between Inner Primary and Transmission
It's not OVER FULL of transmission oil is it???? I took my 06 Ultra in at 20K and the problem was the shifter shaft leaking. They said I had too much Redline in it. They dropped the level a verry slight amount and it quit leaking. That was 5 k ago anf all's well. There is not a wet spot anywhere after that. go figure.... Dan
drspencer
05-24-2012 10:59 AM
