What size primary drain plug are people using on their '06 Tou'06 Road King primary drain plug size?
RE: What size primary drain plug are people using on their '06 Tou'06 Road King primar
I used a 3/16 hex wrench. allen wrench this morning on my 06 my Ultra to drain the primary oil. The side, chain adjustment cover is 27 torx. the Oil pan and trans pan drain \\; bolts are 5/8 hex. \\;
Thanks, that's what I've used on all the other bolts, but the manual doesn't say what the primary plug drain is. I've been using a T30 and that seemed to fit. Must be similar size to the 3/16. When I did a search I saw some other guys using the 3/16 hex wrench.
The manual also doesn't tell you the size of the nuts on the clutch when doing a clutch adjustment.
ORIGINAL: dgriffith
I used a 3/16 hex wrench. allen wrench this morning on my 06 my Ultra to drain the primary oil. The side, chain adjustment cover is 27 torx. the Oil pan and trans pan drain \\;\\\\\\; bolts are 5/8 hex. \\;\\\\\\;
ORIGINAL: petemac
