Adjustable Rider Backrest by Harley???
I have a question on the Adjustable Rider Backrest by Harley. \\; Where does the backrest adjuster mount?
The online pictures show the adjuster mounting on the left side center of the seat. \\; My friendly salesman says that it mounts on the left side front of the seat and that it will interfer with the mid frame heat deflectors.
So which is it, front or center? \\; Will it interfer with the heat deflectors or not?
I have a 08 EGC. \\; The P/N of the backrest is 52622-03A. \\; I am using the Kuryakyn heat deflectors.
Thanks,
Thanks,
RE: Adjustable Rider Backrest by Harley???
Can I hijack this a bit if you don't mind. \\; Does this backrest fold down (Forward) flat then not in use? \\; and exactly how does is adjust? can it be done while riding or do you need tool to change it between rides.
Thanks alot
Harpoon
Thanks alot
Harpoon
ORIGINAL: harpoon
Can I hijack this a bit if you don't mind. \\;\\\\\\; Does this backrest fold down (Forward) flat then not in use? \\;\\\\\\; and exactly how does is adjust? can it be done while riding or do you need tool to change it between rides.
Thanks alot
Harpoon
Thanks alot
Harpoon
backrest is spring loaded or piston cant remember. \\; no when not in use it does not lay flat it can be pussed foward to allow passanger to get on. \\; you can adjust the backrest while riding you just pull the tab under you left leg and released the spring.
i had the harley heat deflectors on mine just like the kuryakin ones and it was one or the other as they both mount in the same place and the sheilds are a little futher in so you really wound be able to get to the adjustment tab. \\; I have heard that the rj deflectors will work with the adjustable backrest just fine. \\; may pick \\; up a set myself but heat hasnt been to bad after putting true duels on.
