Are turn signals interchangeable?
Can the rears signals be used on the front of a RK Classic? Thanks, Roy
RE: Are turn signals interchangeable?
Why do want to do it? \\; One has two wires and other has single wire because one is used for running lights.
Not to my knowledge. The wiring is different. You might be able to rig it to work but what's the point?
Trying to post. Type a short paragraph and it won't work.
I'm trying to match front signals to the shortened rear bar with bullets. I can only find a pair of rear bullets that match.
How about 69577-06, custom bullet front turn signal kit for FLHR's
Dawg, I have the passing lamps and simply want to replace the stock signals that are mounted to the bar. Those look like bolt up to the fork uppers.
Okay, how about this 69063-03?This is the kit you need for both front and rear, or you can have a parts guy break the kit down on h-dnet for you to get the parts for just the fronts
http://www.harley-davidson.com/media...pacer_e204.gif http://www.harley-davidson.com/media...pacer_e204.gif http://www.harley-davidson.com/media...03_M_1baa6.jpg |
yes
You need two of pn#69165-03 $37.47 retail each.
© 2024 MH Sub I, LLC dba Internet Brands
