Anybody Installed This Automatic Compression Release?
Is it an easy install? Does it work?
Automatic Compression Release Automatic Compression Release (ACR) valves reduce the strain of starting your high performance motor by reducing cylinder compression - automatically! The engine is easier to turn over resulting in less wear on your starter and battery. After start, the ACR valves close to restore full compression. ACR give you peace of mind and protects your investment. ACR can be installed on stock or Screamin' EagleŽ Performance cylinder heads for all '07-later Twin Cam equipped models. Install requires matching tobeperformed by a competent machinisht using the Screamin' EagleŽ Automatic Compression Release Fixture Kit P/N 94648-08 (sold separately). Installation requires separate purchase of model specific ACR Wiring Harness P/N 70623-06 or 70623-08. 28861-07A |
I have the ACR on my 110 SE heads work flawlessly so far.
© 2024 MH Sub I, LLC dba Internet Brands
