Hard to start when cold
Old Jan 9, 2009 | 06:47 PM
hgarzatx's Avatar
hgarzatx
6th Gear
Unhappy Hard to start when cold
My 2002 Electra Glide is hard to start when cold I have to open the throttle all the way in order for the motor to start. any Idia as to what is wrong with it? it works fine after it worms up.
Old Jan 9, 2009 | 08:49 PM
Mick's Avatar
Mick
Firstly , welcome to the forum.
Is the bike carb or EFI ?
Mick
Old Jan 9, 2009 | 08:54 PM
ord sgt's Avatar
ord sgt
Did you try pulling out the choke?
Old Jan 9, 2009 | 09:31 PM
FLoTR's Avatar
FLoTR
I get the same way when I get cold
Old Jan 10, 2009 | 08:13 AM
Heathen's Avatar
Heathen
Originally Posted by flotr
i get the same way when i get cold
perfect !!!!
Old Jan 11, 2009 | 07:19 PM
hgarzatx's Avatar
hgarzatx
6th Gear
It is EFI. It does not have a choke. it has electric fule pump.
Old Jan 11, 2009 | 10:46 PM
Agnes the dog's Avatar
Agnes the dog
I was having the same problem with my 00 RK. You should try adjusting your idle. You will have a cold idle and a warm idle. My cold idle was all jacked up. Here's a link on the procedure for the MM bikes:
https://www.hdforums.com/forum/engin...m-systems.html
If you have the Delphi (which you may very well have) the procedure may be different.
The idle adjustment fixed all my problems though. Good luck!
falconbrother
EVO
22
Dec 19, 2018 05:26 PM
atwa
Oct 4, 2012 10:27 AM
MGN54
Nov 7, 2010 07:00 AM
EdGlide
Exhaust System Topics
Nov 1, 2007 10:33 PM
EdGlide
Jun 21, 2007 05:23 PM
