Power Commander Install & Setup
Old Jan 27, 2009 | 09:10 PM
  #31
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
I ordered the PC III from Jamie today. Can't wait to hook it up
Old Jan 28, 2009 | 01:17 PM
  #32
tzman's Avatar
tzman
Talking
I got my FM setup yesterday and installed it all this morning. Wow!!!
The bike runs flawlessly and with lots of power. 0to80 in no time. EEHA.
It was real simple to install. The biggest PITA was the TB support screws. Used a small Allen wrench to get them out. There is no decel pop or accel hisitation. Fuel Moto guys are on it!!!
PC V
SE A/C
Jackpot Mufflers
Old Jan 28, 2009 | 03:50 PM
  #33
IAMSWUTIAMS
My buddy ordered his PC V yesterday, and got it this morning before 10 AM. Fuel Moto rocks!
Old Jan 28, 2009 | 04:34 PM
  #34
Conehead's Avatar
Conehead
PC V
SE A/C
Jackpot Mufflers
+2 on getting that black bracket off, not all that hard just takes awhile to get those screws out. I actually put mine back in after removing the bracket.
Old Jan 28, 2009 | 08:32 PM
  #35
iclick's Avatar
iclick
Originally Posted by HDRider2002
I will let you know when i get mine installed if the 9v was necessary or not to get power to the unit, or if it pulls its power from the bike when the ignition is on.
I should've mentioned that you can do the settings with the engine running, but I don't like revving the engine in neutral with no load on it.
Old Jan 28, 2009 | 08:44 PM
  #36
iclick's Avatar
iclick
Originally Posted by SG 1
iclick, thanks for the replies to my question and others. I printed the one's I needed for future reference. I've got a couple other projects going on (gotta make a little time for work too) and the weather is about to turn crappy again. Louisiana weather.......go figure. I will be checking and setting if necessary the throttle position first chance I get. Thanks again for the heads up.
No problem at all. BTW, I'm in BR and the weather looks good for tomorrow. Should be the same in Monroe. When we talk of "crappy weather" the guys in the frozen north enduring record cold will laugh at us. To us "crappy" is a few days of cold and/or rain that keeps us from riding.
Old Mar 18, 2009 | 12:44 PM
  #37
IAMSWUTIAMS
I have a PC V question. With the auto tuner, if you add a performance cam, do you need to adjust anything, or will the AT do it all?
Old Mar 18, 2009 | 01:05 PM
  #38
HDRider2002's Avatar
HDRider2002
I think i need to "re-do" my TP now that the weather has gotten warmer. When i installed it originally i let the bike warm up, but had to do that just letting it run, not riding it. Gonna have to pull the laptop out one of these nights after a little ride and re-zero it!
Old Mar 18, 2009 | 04:43 PM
  #39
Badbagger's Avatar
Badbagger
UPDATE: Here's an update to my situation. I'd emailed Jamie the specifics and called me last night. When I get back home on Saturday, I'm going to upload the new firmware to the unit and we're hoping that will resolve the issue and if not, we'll replace the unit. I'll keep this updated incase others have the same issues down the road.
Old Mar 18, 2009 | 05:21 PM
  #40
iclick's Avatar
iclick
I just made a cam switch last week and I started with a close map provided by Jamie, then let the bike tune itself. I first established a good rich base map by using Jamie's original target AFR's, then rode the bike for one day through all RPM and TP areas. That established my base map for the bike after selecting "Accept Trims," and I then altered the target AFR's for better gas mileage. The bike has since been auto-tuning as I ride. I can now use my switch to toggle between the richer base map and leaner closed-loop mode.
There is a minor snag, however, in that Dynojet recommends not specifying target AFR's in the 0% column. The problem is that longer-duration cams will fool the MAP sensor into forcing richer-than-normal AFR's in the low-end and midrange. Without going into gory details, which I will later if anyone is interested, I solved these minor issues by making a few adjustments. Those areas with target AFR's take care of themselves.
