Review on SE 255 cams
No the 255 is chain driven. There are not very many late model bikes running the gear drives. I don't think you can get it in gear drive.
yep
Having the SE255 cams and the other mods listed below, I find it hard to believe that a touring bike going 50mph in 6th gear (lugging) with two people aboard uphill can accelerate quickly. I know I have a 96 and their's are 103 but it's still hard to believe. My 6th gear is useless unless I'm between 65-70mph.
I agree completely, To me, it really doesn't matter where the tq kicks in on all these cams anyway. With these sorry *** cranks they have in the late model bikes, you have to down shift when you go below 2 grand anyway. When I'm at 2 grand in any gear but 6th, I can pull a truck. When I get between 2500 and 3 grand in 6th, I've got all kinds power.
It won't be cheaper if you do the job yourself. If you pay to have it done the cost of extra labor might be higher than the cost of the pushrods ($150), as it adds a couple of hours to the job.
Shouldn't be unless you have a 103 w/o ACR's. CCP for a 96" motor is 186 psi, not much higher than stock, and 203 psi for 103's w/o ACR, but all factory 103" motors have them (except the old pre-2007 CVO).
To all who may be considering these, you can usually find a good set of low-mileage CVO pulls on Ebay at any given time for around $150. Mine cost $110 four years ago just as they were starting to get popular, which was a great bargain. Do the job yourself, reuse the stock pushrods, and you can do the job for $200-250 if you can borrow a bearing puller/installer--or buy a Beatty tool for $100.
My results are much like most others who've reported here and elsewhere. They provide a very nice torque increase down low and in the midrange, with an effect much like taking the stock TQ curve and moving it straight up about 10 ft/lbs. Contrary to popular belief they do actually bump HP a bit at the limit, maybe 5% over stock. Statements that they "run out of breath," etc., is not something I've noticed, as mine pulls all the way to the 6200-rpm redline without peaks or valleys in the torque curve. They won't produce top-end power like most other performance cams, but most of my riding is under 4000 rpm anyway, and the way my bike runs I don't routinely need to rev it past that point.
buildnman
02-20-2009 07:21 AM
