Oil Change Procedure
Old Feb 10, 2009 | 08:01 AM
stevepacman's Avatar
stevepacman
I bought a $1 plastic pitcher from Wally-World at marked it for 38 ounces for my primary oil. Sure, I have Poindexter tendencies but you can never get it wrong.
Helped a bud with an '06 RK Custom do his 20k service over the weekend. I was slightly lost at first since HD made the changes to the engine/trans/primary in '07. (Drain & fill plugs locations were different.)
Old Feb 10, 2009 | 08:04 AM
elPrez's Avatar
elPrez
I sliced a 2 liter soda bottle and made a simple way to add the oil through the derby cover. Basically made a sheet of slightly curved plastic that creates a ramp to pour the oil down.
Old Feb 10, 2009 | 09:56 AM
HDRider2002's Avatar
HDRider2002
For adding the oil through the derby cover i just put a small plastic threaded "nozzle" on the primary fluid bottle, which allows me to pour from the new smaller opening in the bottle. That way i can make sure it all get in around the clutch plates.
Old Feb 10, 2009 | 10:26 AM
TMART's Avatar
TMART
One thing I learned from my early years with Hondas,I torque everything to specs.including drain plugs and derby covers,I have yet to have any stripped bolts heads or threads yet.
Old Feb 10, 2009 | 10:47 AM
pigpipes's Avatar
pigpipes
I always fill thru the derby cover so I can check the fluid level at the bottom of the clutch spring.
Old Feb 10, 2009 | 10:54 AM
Leftcoaster's Avatar
Leftcoaster
What the newest editions of the service manuals omit (due to editing, I presume) is that the primary oil changing procedure (POCP) can only, and this is very important, only be attempted on the third Tuesday following the month's full moon. They also leave out the sacrificing of your neighbor's Goldwing and displaying the disemboweled machine in his front yard as an offering to the Gods Of Proper Harley Maintenance a minimum of two weeks prior to starting the POCP.
Old Feb 10, 2009 | 11:24 AM
HDRider2002
Took me a few years to realize that just because the bike costs so much, that the motor isn't rocket science. Its been said before on here, but for the most part these motors aren't anything more than fancy tractor engines Regular maintenance is of course important, but they also withstand a fair amount of abuse as well!
Old Feb 11, 2009 | 09:18 AM
Bushy's Avatar
Bushy
in the manual there are specific amounts for each fluid. get your wives measuring cup and use it. wash it afterwards or she will be really pissed, {ask me how I know that} and just watch those torxs on that ride, use good tools and good judgement. happy motoring!!!
Old Feb 11, 2009 | 09:35 AM
jimmything's Avatar
jimmything
for adding the primary fluid, I just saved the bottle from the tranny fluid which had a long nose and you could squeeze the oil out. Made it a breeze.
Old Feb 11, 2009 | 10:12 AM
mainshaft's Avatar
mainshaft
Most things are pretty easy to do, remember that if you shouldn't have to beat some thing or pry it(in most cases). If it doesn't smell right, look right or feel right some thing is probably wrong. The manual is your friend.
Curt1953
Aug 16, 2015 03:11 PM
hawgsickle
Oct 28, 2009 04:05 AM
my06NT
Jun 18, 2009 11:15 PM
curnaco
May 31, 2008 10:09 PM
mayfiebl
11
Oct 6, 2007 09:34 AM
