Harley Davidson Forums
Harley Davidson Forums (https://www.hdforums.com/forum/)
-   Touring Models (https://www.hdforums.com/forum/touring-models-11/)
-   -   Won't start (https://www.hdforums.com/forum/touring-models/341399-wont-start.html)
Bikermike Apr 25, 2009 03:33 PM
Won't start
Have a 09 street glide that I just put a 103 kit on and at the same time I put apes on it,have not started it since,when I try to start it, all the lights work but it will not turn over and the fuel pump has no current to the fuse in or out of fuse to fuel pump or to the starter.Current is coming out of ignition swith.Any idieas?
Thanks
hogbag07 Apr 25, 2009 04:24 PM
Check all the fuses and your battery for a lose connections. Has your bike got a alarm system
Bikermike Apr 25, 2009 07:39 PM
I have checked all fuses,battery connections are good and I have no alarm.Also
checked all the molex connections to make sure I had them in the right slot after replacing
them.
Lucky 13 Apr 25, 2009 08:15 PM
I would think the problem could be in the kill switch. Without that circuit the fuel pump won't run and you did install apes. I'd be checking the wiring for the handle bar wiring.
ucommbxny Apr 26, 2009 02:57 AM
you may have pinched a wire in right side switch housing during reassembly
cycletrash98 Apr 26, 2009 07:10 AM
does your turn signals work???
https://www.hdforums.com/forum/touri...idge-ride.html
Bikermike Apr 26, 2009 09:07 AM
Turn signals and all the lights work great no problem.Unhooked the fairing haness to both left and righthand controls,there is no current getting to the base of the bars coming from fuse box except for lights, horn and radio.The start switch or kill switch or cluth lock out switch have no power.
All fuses are good but when you turn key on fuel pump fuse is the only fuse that has no current in or out of it.
Harleypingman Apr 26, 2009 10:51 AM
Can't help, really; but, the HD Electrical Diagnostic Manual would be the first place I'd look for an answer if I've exhausted my own, limited, diagnostice resources.
Hope you find the fix quickly.
Bikermike Apr 26, 2009 12:57 PM
Thanks for all the ideas,I'am getting a little frustrated,I know it is something real simple.
© 2026 MH Sub I, LLC dba Internet Brands
