Does anyone have the HD Mini Tour-Pak Lid Rack Dimensions Part number 53100-96? I'm looking for the overall dimensions of the rack and then also the spacing on the mounting legs/points.
It's approximately 11" long X 8-1/2" wide but tapers slightly narrower towards the front. The legs are mounted at approximately 8" apart side to side X 7-1/4" front to back. Hope this helps you?
This is exactly what I wanted to know, thanks! I appreciate the pictures as well.
For all those searching, the actual dimensions of mounting holes are 7-1/4” wide at front, and same 7-1/4” center to sender of holes on two sides. The back holes are 8” centers, these match exactly, the factory holes provided in the steel lid support on the inside of the leather wrapped tour park. So drill from inside out and mini rack 53100-96 will be super secure bolted to top of mini rack. I’d drill holes slightly smaller in leather so it stretches to seal around screw..
