Road King Gas Mileage and miles to empty when gas light comes on?
Well, my gas light came on riding to work this morning and about 10 miles later the bike cut off. I coasted about 200 yards and then it popped back to life and rode a bit further until it cut off again. Then "luckily" I coasted to the next exit and was able to make it to the gas station.
It took 4.9 gals to fill it up and I went 170 miles on that tank. However half of it was when the motor was stock, the other half is with the stage 1, PCV, and rineharts.
Whats the size of the tank and whats the reserve? I have a 07 Road King Classic. I have smelled gas pretty frequently since installing the PCV which leads me to believe the unit is dumping way more gas then it should and making it run rich. I am in talks with FuelMoto about this (and Jamie has been wonderful in helping me figure it all out).
But I still want to know what avg I should be getting so I can check with this next tank of fuel. Thanks.
That sounds like you're running way to rich if you're only getting 170 miles per tank...I have PCIII and V&H and depending how much I twist the trottle, I start looking for a place to re-fuel at at 170 miles. Normally when my low fuel light comes on I have approx. 1 gallon of fuel left. If your bike is EFI there is no reserve.
Isn't your bike fuel injected? FI's don't have a "reserve". That's a carb/petcock thang. FI's run till they're dry, then they quit.
Both the fuel gauge and low fuel light are "approximate" at best, but you can adjust their readings to suit you by bending the float rod inside the tank. Your service manual tells you how to access it.
My '08, same way, but usually the "miles remaining" hits "lo" (below 10) when I have about a gallon left. I consistently put five gallons into my six gallon tank when my electronic "crutch" says I am empty. I usually start looking for gas at about 180 but don't sweat it even when at 200. I ran it dry just to see once and got 232 miles before I had to pull over and empty a jug into her.
