round nostolgic air cleaner cover question
Can anyone clear up some conflicting information I am getting? I would like to change out the stock air cleaner cover on my 09 Road King to the round nostolgic cover. I am told to do this I need to purchase the Stage 1 kit for the round cover to fit. Also, the Harley parts catalog says that a re-map is required but the parts guy at my local Harley Dealership says a re-map is not necessary. Who's right? and do I need to purchase the stage 1 kit in the first place? I am not looking for performance just looks.
Thinking about this myself. I had the round air cleaner installed on my 08 Street Bob. I swithched out the SE air filter for a K&N filter. When I traded it in for the Street Glide I had them change out the filters to get my K&N filter back. I also had just the A/C plate cover from AZECE.com that I got back.
My plan was to just buy the Back Plate kit HD part #29319-08
and the o-rings, breather tubes and breather screw kit and put the K&N filter and cover plate on the Street Glide.
Anybody know if this would work?
To put the round AC cover on, you need to install the SE backplate or the Ness Big Sucker backplate. Anytime you change the intake, you need to remap the ECM. Think of it as rejetting your carb and adjusting the air fuel mixture to accommodate the freer flow of the new backplate.
If you change the exhaust, you do not necessarily need to remap the ECM.
Remapping can be done with Mastertune TTS or SERT or you can use a module that is left on the bike like the Power Commander.
there is one more item you're going to need when installing the round nostalgic air cleaner cover. it's a thick gasket that sticks on the inside of your chrome air cleaner cover. it's the part that prevents the air cleaner from spinning around on the center screw, it's about five bux from harley. it's just under 3/16" thick, and has adhesive on one side. there are also two types of the round nostalgic air cleaner. one has a cut out across the top to clear the fuel tank. the other one does not have the inch wide cutout. be sure before you install it that your motor isn't gonna rock enough to dig into the paint of your tank with the air cleaner cover.
