Inherrited problems
Old Aug 21, 2009 | 03:24 AM
Mike in Oregon's Avatar
Mike in Oregon
Question Inherrited problems
Anything else other than cam tensioners and squeaky brakes on the 05' Road King Custom I should be aware of??? TIA guys!
Old Aug 21, 2009 | 06:51 AM
Road Ranger's Avatar
Road Ranger
Some of the 05's had problems with valve guide seals. I haven't had any issues though.
Old Aug 21, 2009 | 08:04 AM
rags's Avatar
rags
+1 on the valve guide seals. I had bad valve guide seals on one cylinder. The first place to look if a 05 is using oil.
Old Aug 21, 2009 | 09:06 AM
gibby122's Avatar
gibby122
squeeky front brakes just starting, 9000 on an 50 RK Cust.
Old Aug 21, 2009 | 10:36 AM
PhilM's Avatar
PhilM
05 was a good year. Things began to change in 06 and then 07.... 08....09.....xxxx....xxxx
I only put 10k on it before having the heads done, so I never experienced any of the valve seal anomalies. As I recall, there was a production change to address the seals mid year (orange vs blue or black or something like that).
My 05 rocks. "For me", nothing since then has made be consider a change...
Old Aug 21, 2009 | 04:49 PM
Mike in Oregon
Thanks guys!
Old Aug 21, 2009 | 05:17 PM
Uncle Scrooge's Avatar
Uncle Scrooge
You might want to put Heim joints on the shifter rod. Easy, cheap fix to avoid having the rod come loose at one end or the other. Do a search, as there are lots of posts about it.
elwoodto
Exhaust System Topics
Jul 4, 2008 08:29 AM
asputin
Jan 20, 2008 05:20 PM
roxbury241
Oct 10, 2007 05:05 PM
05flhr
Apr 24, 2007 11:57 PM
joe v
Nov 22, 2006 11:36 PM
