Satellite Radio Suggestions
http://shop.sirius.com/edealinv/serv...dParentID=7872
If you think you can hear the sound quality difference on a bike rolling down the highway at 70mph I think you're nuts. Or else you had a significant problem with your installation. The sound quality is not bad at all if you go via the direct wired FM route.
Maybe it's different using the FM in on the HK's than it is on the aftermarket radios and the GM systems in my truck.
The other issue I had was getting reception. With the antenna in the faring I had significant signal drop issues. Moving it outside the faring on my GPS bracket cured that but I am not crazy about the looks of it.
After messing with it for a while on the bike I just formed the opinion that I was better off with the MP3 player. In Hind sight I would save my money and spend it on other things more useful. YMMV
Most people don't listen just at 70 mph. It's a fact the sound quality is not as good when you FM modulate. The AUX input is the best quality sound.
I have the Harley Road Tech XM radio receiver mounted on my left handle bar mount just as HD designed it. It's water proof, reasonably theft resistant as it's bolted on ,not just "attached". I never take it off, never fool with it. Has worked flawlessly for about a year and a half so far. I have the hook up wire routed across the bottom face of the HK radio system and stuck onto the face with two sided taped. Black wire almost blends in and is virtually unseen. I plugged it into the aux. inlet on the HK radio, everything works great. Power source is with a "cigar lighter" type plug in I put on the left side of the fairing You could actually hard wire it in to keep this plug recepatcle free for other things since removal of the XM receiver is not really something you will be doing. Only negative I can hear is the volume of running thru the Aux input is not as loud as the regular radio or CD volume. Not a big deal, but some less volume can be expected. Solution is: turn up the volume.....
The part number is 52423-09A. It's the Comfort Stitch Style Adjustable Backrest and I like it a lot. I had rented an 08 Ultra before purchasing my 09 model and after 3 days and 1100 miles, I knew I'd want a drivers backrest so I had the dealer install it before delivery. It's adjustable fore and aft as well as up and down a little. It's well worth the money IMO!
Ride Safe,
Steve R.
