TSM Trouble Codes
First of all, I don't have the service manual with me. But I did a search here and found a thread that lists the trouble codes for a TSSM. I don't have security and I'm getting a 31 code, which is alarm output high on a TSSM. Does anybody know what that code would be for a TSM?
31 is "alarm output low" not high on either the TSM or TSSM. The code is the same
32 is high..... it will probably clear in about 50 run cycles of the ignition. you need the electrical diagnostics manual for codes..a regular service manual probably wont have them....the part # for your 2002 touring bike is 99497-02 |
You are correct, it's low not high. I just thought it was odd that it would have this code with no security. I will probably pull the TSM tonight and clean the connections to see if that takes care of it.
© 2024 MH Sub I, LLC dba Internet Brands
