07 sg died
Old Oct 12, 2009 | 11:13 PM
CroK's Avatar
CroK
You could have been anticipating a right hand turn then hit the kill switch instead of the turn signal... Sounds funny, but like I posted in another thread, it DID happen to me!
Old Oct 13, 2009 | 05:59 AM
Da Gumpmeister's Avatar
Da Gumpmeister
THINK............................................. ........RIDE BELL !!!!!
Gremlins will sometimes "appear", as an electrizical short. Li'l BASTUDS !!!!!
IF, by chance, you already have one, THEN check for codes, tight connections, and WATCH THAT THUMB
Old Oct 13, 2009 | 07:03 AM
BadBobOk's Avatar
BadBobOk
Originally Posted by cowboy-bc
Hi all,
So I'm flying down the highway yesterday about 120 k with a full tank of fuel and the bike just dies. So I pull over turn off the ignition then hit start and it starts and no more problems? Anyone have tis happen?
120k? Isn't 120,000 mph getting pretty close to Warp 1? Maybe you need to flash the ECM for Warp speeds.
Old Oct 13, 2009 | 07:26 AM
hogwash's Avatar
hogwash
Just happened for the first time a few weeks ago on my 07 SG. I'll have to do a search on the speed sensor...
Old Oct 13, 2009 | 07:36 AM
schumacher's Avatar
schumacher
It really didn't happen......it was just yer imagination
Old Oct 13, 2009 | 08:37 AM
Tony P's Avatar
Tony P
Originally Posted by Splatter
Mine sure did.
There are a lot of posts on here that describe a similar problem. A large number are reported to be loose battery cables. Second place seems to go to speed sensor.
Mine died once from a loose wire on the harness.
Old Oct 13, 2009 | 08:46 AM
bwana1's Avatar
bwana1
My '06 did it one time, 65000 miles ago. I attributed it to "possible" water in the gas or gremlins.
Bwana
Old Oct 13, 2009 | 11:12 AM
FastHoss's Avatar
FastHoss
You must have been to Harley tech school!
Old Oct 13, 2009 | 01:25 PM
dyna07custom's Avatar
dyna07custom
Originally Posted by oldairboater
Intermittent electrical problem. Did the bike throw any codes? If it happens again look at speedometer/odometer and see if it does something unusual. For starters I would check my battery connections and other terminals to see if they are clean, tight and nothing is odd.
+1 easy place to start
Old Oct 13, 2009 | 01:31 PM
tjvrodrick's Avatar
tjvrodrick
My bet the battery cables not clean or tight.
